layer set control
crosscutter55
hi i am using hd pro 2017 how many diffrent areas are there to shut off & on ceiling joists  ? when i go to layers and uncheck ceiling joists it does not control that layer !!  How many areas are there to control this ?
In other versions, It use to be when you shut a layer off or on in the layers  it did just that !!!!!
You may be confused by the fact that in fact there is not just one Display Options dialog. Each camera view type and plan view each have their own Display Options dialogs. That means that "ceiling joists" could be off in Plan view but still "on" in each camera type views.
This is not unusual to 2017 but has been programmed the same for over ten years.
