ErlendArge Posted October 12, 2016 Share Posted October 12, 2016 I use HD Pro for Mac. I am trying to create a layout template and are following the tutorial for layouts. I am creating a rectangular polyline and are following instructions to create fillet corners (page 188 in the user guide). After setting the Fillet Radius I am instructed to select the polyline an click the "Fillet All Corners" button. I was expecting to see that button next to the Fillet Radius button but did not find it there. After using 15 minutes now to find it I must conclude that it is hidden quite well or even disappeared totally. Have anyone an idea where it could be? Link to comment Share on other sites More sharing options...
solver Posted October 12, 2016 Share Posted October 12, 2016 This is from Chief. Check your Edit Toolbar. Make sure the tutorial you are following is applicable to Pro. Link to comment Share on other sites More sharing options...
ErlendArge Posted October 12, 2016 Author Share Posted October 12, 2016 Thanks Eric, Attached is a corresponding screendump from my software. As you can see, the Fillet All Corners button is missing. Link to comment Share on other sites More sharing options...
solver Posted October 12, 2016 Share Posted October 12, 2016 Did you verify the tutorial was for Pro and not Chief? I just started my copy of Pro and the Fillet All Corners button is not available. Link to comment Share on other sites More sharing options...
ErlendArge Posted October 12, 2016 Author Share Posted October 12, 2016 It is the Home Designer Pro 2016 User's Guide page 188, see attached clipout of the relevant section. Link to comment Share on other sites More sharing options...
solver Posted October 12, 2016 Share Posted October 12, 2016 Have you tried to add that button to the toolbar? Link to comment Share on other sites More sharing options...
ErlendArge Posted October 13, 2016 Author Share Posted October 13, 2016 No, I have not found that button anywhere. Link to comment Share on other sites More sharing options...
solver Posted October 13, 2016 Share Posted October 13, 2016 I'd suggesting contacting Chief. The documentation may be wrong. Link to comment Share on other sites More sharing options...
