BrandonJJinkins Posted October 10, 2016 Share Posted October 10, 2016 Hi folks, couple questions: I need to recreate the following conditions and I'm having trouble. For the arched opening I've created a doorway, but I cannot seem to "unlock" its settings to adjust its height, or figure out a way to "bypass" the 4" jamb to actually move it against the wall. Then there's a curved step that right now I have drawn as just a rectangular slab. Link to comment Share on other sites More sharing options...
solver Posted October 10, 2016 Share Posted October 10, 2016 Slabs may be curved. Use the convert line to arc command. Did this in Chief, but should also work in Pro. You may need to check Ignore Casing on Opening Resize -- look it up in Help. Link to comment Share on other sites More sharing options...
BrandonJJinkins Posted October 10, 2016 Author Share Posted October 10, 2016 Well, not EXACTLY what I needed, but pretty darn close! I'd have never found that Ignore Casing on Opening Resize option. Thank you! Link to comment Share on other sites More sharing options...
