retiredmarine Posted October 3, 2016 Share Posted October 3, 2016 I'm trying to draw the roof that goes with these trusses To fit this design.. ANY help would be appreciated.. I'm using Home Designer Suite 2016. frame only 2X4 walls.plan Link to comment Share on other sites More sharing options...
katalyst777 Posted October 3, 2016 Share Posted October 3, 2016 You've already got a 6/12 gable roof in your design over the structure and decks, but that's about the extent that Suite will let you do.See this prior thread - https://hometalk.chiefarchitect.com/index.php?/topic/1193-scissor-truss/You can't add Ceiling Planes like Pro would let you to make a true vault, but you can follow these instructions to create a cathedral ceiling.KB-00160: Creating a Cathedral Ceiling 1 Link to comment Share on other sites More sharing options...
retiredmarine Posted October 3, 2016 Author Share Posted October 3, 2016 Katalyst777 I get that but here's what I'm trying to do - even with a 6/12 roof the bottom of the trusses don't land on thin inside wall. If you look at the truss design it should land on the inside wall and then extend 8 feet out over the porches on either side. However in my plan, as I have it nouw, the trusses land on the outside supports on the outside of the porches. make sense? Link to comment Share on other sites More sharing options...
Jo_Ann Posted October 3, 2016 Share Posted October 3, 2016 You have made your attic walls invisible, therefore they are not showing as reaching the roof underside. If a lower cathedral ceiling below the trusses is what you want, you can model a slanted ceiling plane in sketch-up and import it into your model. OR...you can upgrade to HD Architectural and use a sloped soffit to represent that ceiling plane. Link to comment Share on other sites More sharing options...
katalyst777 Posted October 4, 2016 Share Posted October 4, 2016 Sounds like Jo_Ann has a better handle on what you're trying to ask. Link to comment Share on other sites More sharing options...
GLOBE-Res Posted September 4, 2017 Share Posted September 4, 2017 As a professional designer keep in mind that what is important is that YOU don't need to worry about what the truss will look like, that is the architect or designer's job. The Truss supplier is going to take your plans and elevations, send them to the manufacturer who will actually design the roof trusses for the project. The building section that is being generated by the designer comes partly from the roof manufacturer, we simply plug in the information as a "visual" indicator for the builder. Link to comment Share on other sites More sharing options...
