studiostarrs Posted September 28, 2016 Share Posted September 28, 2016 HELP!I need two soffits on the ceiling which help define the space.As soon as I connect them, they create a "drop-down" ceiling which I don't want.I want it too look just like this--only connected.What am I doing wrong? Link to comment Share on other sites More sharing options...
solver Posted September 28, 2016 Share Posted September 28, 2016 Please take a minute and fill out your signature -- see below. Knowing what software you are using is often key to providing a suggestion. Soffits don't create things. Could you post a picture showing what is happening. -------------- It helps if we know what title (Suite, Pro etc) and version (2014, 2015 etc) you are using. You can add this info to your signature by clicking on your user name at the top right of the page, click My Settings, then Signature on the left. Resources for self help: The built in Help System (always a good place to start) Getting Started Knowledge Base YouTube Link to comment Share on other sites More sharing options...
DavidJPotter Posted September 28, 2016 Share Posted September 28, 2016 In older versions the way one would "face" the soffit objects can cause them to fill in one to the other but I do not think that is now the case but you might try rotating the soffits in plan view 180 degrees to see if that helps at all. I agree with Eric that we need a copy of the plan or at least a picture of the anomaly so we can better understand what actually is happening. DJP Link to comment Share on other sites More sharing options...
