Foundation CAD Details
JohnnyD
If you can find them in a DXF format somewhere, you can import them in as line drawings and then edit as needed since your signature says you have Pro.
Here's one site that looks like it has some.
http://www.apacad.org/?q=foundation
Also, if you can find them as DWG files, you can convert them to DXF too using something like this DWG to DXF converter.
Most of the Home Designer programs don't have the tools, or need, to create these, so you might want to post on ChiefTalk in the Symbols & Content section as well.
Or just go ahead and start from scratch following the instructions in the Knowledge Base article KB-00439: Creating a Cross Section Detail in Home Designer Pro since it doesn't look like it would actually take much time.
