FooBear Posted September 14, 2016 Share Posted September 14, 2016 HD Architectural 2016 (17.3.2.2x64) The Kitchen I'm designing will need both wall and base fillers, and according to the help file "If two cabinets meeting at a corner are separated from each other by 3”(75 mm) or less, the program will automatically generate a filler in the angle between them." I'm finding that I have to be UNDER 3" for it to occur. From a programming perspective it feels like they're checking for "distance < 3", when it should be "distance <= 3". Do I have to try to force them all to be 2 15/16" apart? Link to comment Share on other sites More sharing options...
Solution DavidJPotter Posted September 14, 2016 Solution Share Posted September 14, 2016 You can also just make filler upper cabinets and base cabinets that are 3" wide and manually place them, before auto fillers were added several versions that was the only way it could be done and the old method still works. DJP Link to comment Share on other sites More sharing options...
FooBear Posted September 15, 2016 Author Share Posted September 15, 2016 Okay, I sent it to support as a possible bug. The 3" cabinet workaround works well too, thank you. For anyone else that wants to do it, I had to go into Edit/Default Settings.../Cabinets/General Cabinet and change the minimum cabinet width from 9" to 3". And for each filler cabinet I made, I suppressed the label in the "label" section of the cabinet properties page to reduce the visual noise of a label like BCW330R over a 3" cabinet. Link to comment Share on other sites More sharing options...
