Kitbath Posted September 13, 2016 Share Posted September 13, 2016 How do I use Essentials 2016 to create/design wardrobe in the Attic/Loft or underneath the stairs. Link to comment Share on other sites More sharing options...
katalyst777 Posted September 13, 2016 Share Posted September 13, 2016 Does your version have the "Custom Backsplash" cabinet tool? If so, you can use some of these on walls in order to create the look of cabinet doors. Place hinges and door knobs or pulls from the Library Browser as independent objects.Walls are also already going to get cut off by roof planes, so you can use them and actual cabinets resized for the front of the cabinet doors for the angled back style in a loft. Or you can just use normal Full Height cabinets if you only care about the interior look, but outside will look funky with the cabinet tops sticking out. Link to comment Share on other sites More sharing options...
LawB10 Posted September 14, 2016 Share Posted September 14, 2016 Here what I came up with.. I created a salt box roof, then lowered it to 60", turned off auto rebuild roofs and reset back to default ceiling height. Next I lowered the full cabinets to 71". I used windows and soffits for the other cabinets, you have to use the shape tool to match the roof and then resize. loft cabinet.plan Link to comment Share on other sites More sharing options...
rfcomm2k Posted September 14, 2016 Share Posted September 14, 2016 Nicely done LawB10! Link to comment Share on other sites More sharing options...
