bigriles Posted July 17, 2016 Share Posted July 17, 2016 Im looking to build a triangular shapped cornice under a saltbox roof rafter. it seems to me i did this in the past by turning a soffit into a triangle shape. cant seem to do this now. do i have an edit behavior turned off / guidance please. thanks. Link to comment Share on other sites More sharing options...
Elovia Posted July 17, 2016 Share Posted July 17, 2016 Not sure which Home Designer product you're using. Do you have a triangle shape available in the Shapes Library? Link to comment Share on other sites More sharing options...
bigriles Posted July 17, 2016 Author Share Posted July 17, 2016 pro 16. tried a triangle but can only adjust size in two axis(not dia,) im thinking something is set to limit my adjustment to shape. need to adjust triangle to foof pitch as well(34 degrees) Link to comment Share on other sites More sharing options...
katalyst777 Posted July 18, 2016 Share Posted July 18, 2016 Im looking to build a triangular shapped cornice under a saltbox roof rafter. it seems to me i did this in the past by turning a soffit into a triangle shape. cant seem to do this now. do i have an edit behavior turned off / guidance please. thanks. Are you perhaps thinking of creating a triangular shaped soffit like is described in this earlier thread? https://hometalk.chiefarchitect.com/index.php?/topic/1925-non-rectangular-soffits/#entry10970 Link to comment Share on other sites More sharing options...
