Change brick in a brick wall exterior
gjonesnemeth
I'm a new user but am making relatively good progress using the Chief Architect 2017 version.    I have a working layout which is using a "Brick-4" exterior wall.
However, the house I'm trying to model actually uses an 11.5" wide brick, which is a very different look for the brick exterior.
Are there any catalogs or other trips anyone could suggest about how to add an 11.5" X 2.25" X 3.5" brick?   If so, is there a way to match the color of the brick and mortar?
Thanks in advance.
Best regards,
GJ-N
You can change the scale of materials, as well as blend the material with a different color.  What version of 2017 are you using?  (Essentials/Suite/Interiors/Architectural/Pro)  If you find something similar that tiles seamless across a surface, you can also import your own brick material.
