dmperkins74 Posted May 27, 2016 Share Posted May 27, 2016 Hey gang, I just installed the Home Designer 2016 software and I have a couple of intro questions: - How can I get the measurements to go away? - Can I change the keys used to control the camera at all? - Is there a way to get walkthroughs to have the shadows? Thanks, dp Link to comment Share on other sites More sharing options...
DavidJPotter Posted May 27, 2016 Share Posted May 27, 2016 Your software, whatever it is comes with Help Files, Reference Manual and video tutorials, take a look and learn how to do what you want to do. DJP Link to comment Share on other sites More sharing options...
myplans Posted May 28, 2016 Share Posted May 28, 2016 I am probably not in the right spot but once i place wall breaks how do i remove them. Can find it any place that says how to Link to comment Share on other sites More sharing options...
dmperkins74 Posted May 28, 2016 Author Share Posted May 28, 2016 It's the 2016 version. I've looked through help and I cannot figure it out. If you happen to know, you could you please simply tell me the answers? Link to comment Share on other sites More sharing options...
Solution myplans Posted May 28, 2016 Solution Share Posted May 28, 2016 To remove dim go to Edit Remove Objects check all rooms on this floor under cad ck manual and auto dims and then click delte to resotre dims go to CAD dimensions click auto interrior or auto exterior and they will return I had the same problem had to call CA to find out Link to comment Share on other sites More sharing options...
dmperkins74 Posted May 29, 2016 Author Share Posted May 29, 2016 Thanks a bunch MyPlans. I was searching all over for "show" and "hide" it never occurred to me that this was something I would delete and regenerate. You were very helpful Link to comment Share on other sites More sharing options...
