alexlovelady Posted May 17, 2016 Share Posted May 17, 2016 how do I make a curved wall into a window Link to comment Share on other sites More sharing options...
LawB10 Posted May 17, 2016 Share Posted May 17, 2016 Like solver said you have to be more specific. Generally, you change the material to glass... Link to comment Share on other sites More sharing options...
katalyst777 Posted May 17, 2016 Share Posted May 17, 2016 In Home Designer Pro 2016, on the Casing panel, there's a "Curved Wall Casing" setting. Had to double check the Help button to understand what each of the settings were for. Curved Wall Casing - This section is enabled if the window is placed in a curved wall. Straight - Both window sash and casing are straight.Straight casing may not fit properly into a wall if the window is too wide or the curvature of the wall, too tight. Radial - The sides of the casing or jambs are inserted in the wall at an angle that passes through the center of the curve. Parallel - The sides of the casing are inserted in the wall at a right angle to the line tangent to the curved wall at the center of the window. Normally, parallel casing has a straight sash. Radial casing is more like traditional curved windows, and typically has a curved sash. Is this what you're asking about? Link to comment Share on other sites More sharing options...
