Gothic Posted May 15, 2016 Share Posted May 15, 2016 I have 2 adjoining rooms with different ceiling heights. If I try to place a crown molding in the taller of the 2 rooms, it disappears along the wall that connects with the shorter room. It will appear if I bring the crown molding down to the height of the shorter room, but I want the top of the molding at the height of the taller room. Does anyone know what I need to do to get a continuous molding at the proper room height ? Link to comment Share on other sites More sharing options...
solver Posted May 15, 2016 Share Posted May 15, 2016 Tested in Suite 2016. Image shows crown in correct position in both rooms. Posting an image of what you are seeing, or the plan file (make sure it's not open in the program) will help. Link to comment Share on other sites More sharing options...
