bdaybigstone Posted April 14, 2016 Share Posted April 14, 2016 Make a small 8' tall 8' square block wall room in the 3' crawl space . To add stairs and an doorway to the basement I have on one of the walls . When I make the wall it doesn't give me height to change and if I change ceiling it goes up not down the way I need it . Do I have to start over with foundation ? It 2 different levels Link to comment Share on other sites More sharing options...
DavidJPotter Posted April 14, 2016 Share Posted April 14, 2016 You need to supply the forum with a little more specific data to help you: 1. what software title are you using? 2. can you be a little more specific towards communicating exactly what you are trying to achieve? 3. I do not understand how a 3" crawl space and a basement that is accessed by stairs are the same thing? 4. Images or sketches help a lot in saying what you are asking about. 5. a copy of your plan that others can look at and edit is also useful provided you get across clearly what it is you are trying to do. DJP Link to comment Share on other sites More sharing options...
