BlueMoonInterior Posted March 21, 2016 Share Posted March 21, 2016 I am new to Chief Architect. I have Home Designer Architectural 2015. I don't know what I did, but now ALL of my room labels say ATTIC ?! And, why when I space plan does it add doors to my exterior? And where I don't want them interior? Please help. Thanks in advance. Link to comment Share on other sites More sharing options...
katalyst777 Posted March 21, 2016 Share Posted March 21, 2016 It means that you've defined all of your rooms as the "Attic" room type, maybe for the purposes of generating the roof a certain way?You should be able to reopen each room's Specification dialog and change it to something else if you don't want it being defined as the "Attic" type.I never saw the point of the "Space Planning" box things. So much easier to just draw in the walls you want where you want them and make adjustments that way. Link to comment Share on other sites More sharing options...
DavidJPotter Posted March 21, 2016 Share Posted March 21, 2016 You may have (I am guessing) set "Edit Default Settings - Room" to "Attic" (why anyone would do that is beyond me but could happen). In any case like Kat said, you can simply open each of the spaces named "Attic" and choose a more appropriate name for the space and then go on and finish what you were doing. DJP Link to comment Share on other sites More sharing options...
