DaveTheB Posted March 17, 2016 Share Posted March 17, 2016 I'm trying to model an existing bar in HDPro 2016. I have the bar drawn with a textured glass counter top. That and the cabinets it sits on look fine. Problem is, the existing bar has a piece of 3/4" plywood wrapped in stainless steel sandwiched between the glass top and the cabinets. How can I model this in HDPro? Right now in a 3D view, I can see through the glass and into the tops of the cabinets. Thanks, db Link to comment Share on other sites More sharing options...
Solution DavidJPotter Posted March 17, 2016 Solution Share Posted March 17, 2016 I would use two custom slabs one set to stainless steel and the other to glass, each set to exact thickness DJP Link to comment Share on other sites More sharing options...
DaveTheB Posted March 17, 2016 Author Share Posted March 17, 2016 I didn't know you could spec two stacked on top of each other. Thanks! Link to comment Share on other sites More sharing options...
