Step Down Room
mkozychief
Go to solution Solved by DavidJPotter,
I'm very new to Home Designer Pro and I am trying to design a house where  portion of the structure will be at a slightly different level than the rest of the house (2 six inch steps for a total of 12 inches).  The ceiling/roof structure should be unaffected  by the step down and will remain at the same level.  Any suggestions on how this can be done?  Thanks.
  • Solution
Separate that area with walls either visible or invisible. Then open that area's Room Specification Dialog, go to its "Structure Tab" and uncheck "Default" beside the input box for "Floor" and reset that value to -12". That will achieve the effect you desire.
