Add gable over front entry / windows
cte677
Go to solution Solved by DavidJPotter,
Home Designer Architectural
I'm trying to create a house front similar to the attachment.  The .plan doc is also attached.
1) Porch: I added a room divider for the porch ... not sure how to create a front porch.
2) Gable: How do I raise the height of the room divider? ... so the gables align with the hip roof ... see attachment page 2.
3) Open Gable:  How do I change this gable over the door to be a gable, not a hip?
4) Columns:  I don't see "brick" column as an option.
5) Semi-circular window: How do I add a semi-circular window as is on page 1?
Thanks!
House Bismarck South 160304 01 Inside rooms removed.plan
House Designer porch columns, gables 160304.pdf
