Remove Crown Molding on Ceiling Beam
jrubis
Go to solution Solved by solver,
I made wooden ceiling beams using soffets. The problem I am having is the beams are appearing with crown molding because the wall/floor is set to use crown molding. How do I prevent the molding from appearing on the beams? The soffets do not have a moldling defined.
Soffits will acquire crown (or base) molding if the room is defined for such and if they're connected to a room defining wall that has crown (or base) molding.  If you do not want crown molding on ceiling beams, you have several choices of items top use instead:  slabs, beams, or shapes.
Hope this helps. :)
