davewc55 0 Posted July 16, 2014 Hello, I am using Home Designer Pro 2015. I am trying to create a wall similar to the attached picture. A "horizontal curved wall". Not sure what else to call it. Thanks, Share this post Link to post Share on other sites
DavidJPotter 207 Posted July 16, 2014 I would call it a concave wall, you might be able to use a shape that might do, or you can make such a custom shape in Sketch Up and import it to Pro. (that can be done natively in Chief Premier). A curved mirror might also be made the same way. DJP Share this post Link to post Share on other sites
davewc55 0 Posted July 16, 2014 David, Thanks for the quick response. I will give it try. Share this post Link to post Share on other sites
Kbird1 158 Posted July 17, 2014 yep I'd say Sketchup for a Radius'd wall like that ,perhaps look for a skatebard ramp on 3D warehouse 1st ? you can't change the Library shapes , only their sizes , so you cant eliminate the other half of say a cylinder. FYI Chief/HD doesn't do "leaning walls" either at this stage.... Share this post Link to post Share on other sites
