skimberly Posted December 29, 2015 Share Posted December 29, 2015 OK, I feel like a bit of a newbie here despite having used HDA and its predecessors for at least a couple of decades now. Not much experience with the interior design options though. There must be an obvious answer to my question, but I just can't find it after many searches of the user forums, Users Guide, knowledge base, and so on. My plan has numerous double windows-- not an unusual scenario by any means. I want to add curtains to the windows -- a left-tied curtain on the left, and a right-tied curtain on the right. All I can find in the catalog is a curtain tied to the left. I can't find any way to reverse / flip the orientation for one of the windows so that it will have its curtain tied to the right. I was expecting to find that as an option on the "treatments" tab (or at least somewhere in the window specifications dialog). I've attached a screen shot of what I currently have, using the stock left-tied curtain on both windows. Obviously the curtain on the right-hand window is the one I want to flip (moving the tie-back to the right). Any suggestions as to how I might accomplish that? Regards, Scott Kimberly Home Designer Architectural 10 on Windows 8.1 Link to comment Share on other sites More sharing options...
solver Posted December 29, 2015 Share Posted December 29, 2015 Do you have a Reverse Symbol checkbox when you open (Ctrl-E) the curtain? Link to comment Share on other sites More sharing options...
skimberly Posted December 29, 2015 Author Share Posted December 29, 2015 That's one of the challenges, Eric: I can't open (Ctrl-E) the curtain, as I normally would to try and flip an object. There is no way to select the curtain so it can be "opened." I can select the window itself, but not the curtain as a component of the window. And the window itself can't be reversed -- as far as I can see. Scott Kimberly Home Designer Architectural 10 on Windows 8.1 Link to comment Share on other sites More sharing options...
solver Posted December 29, 2015 Share Posted December 29, 2015 Either apply the curtain directly from the library -- not as a component of the window, or place a curtain from the library on a wall, reverse it, add it back to the library and then use it as a window component. Link to comment Share on other sites More sharing options...
skimberly Posted December 29, 2015 Author Share Posted December 29, 2015 Hmm, I thought option B would do the trick --I was able to reverse the object and place this new reversed curtain in my custom library-- but when I selected the reversed curtain as a window treatment, it just showed up in the original orientation (which is quite odd, because if I place this new reversed curtain on the wall by itself, it does retain the new right-tied orientation). So I guess I have to go with option A -- not as convenient, because the curtain is surprisingly difficult to resize and manipulate when it's a separate object that's not integrated with the window. Thanks for the suggestions though. Link to comment Share on other sites More sharing options...
solver Posted December 29, 2015 Share Posted December 29, 2015 I just tried it -- looks like a bug to me. I'll report since I'm using a current version. Link to comment Share on other sites More sharing options...
solver Posted December 29, 2015 Share Posted December 29, 2015 Response from Support. Thank you for bringing this to our attention. I have forwarded the information to our development team of Software Engineers. In the mean time, the work around would be to place it over the window without using the window treatment specification dialog. Just click on it and click over the window.I apologize for the inconvenience. Link to comment Share on other sites More sharing options...
MPLengyelJr Posted December 31, 2021 Share Posted December 31, 2021 Was there any resolution to this? I have copied the curtain into the user library and reversed the symbol but it does not apply to the window as a reverse symbol. Thanks for the support! Link to comment Share on other sites More sharing options...
solver Posted December 31, 2021 Share Posted December 31, 2021 24 minutes ago, MPLengyelJr said: Was there any resolution to this? Did you try what Support suggested above? Link to comment Share on other sites More sharing options...
