Sign in to follow this
billthdg
Folding Patio Door Walls
I would like to incorporate a folding (accordion) door from my living room to the patio - an opening of ~8' x 12', which would require four 3' door panels.  I am thinking of something similar to the Jeld Wen Siteline folding patio doors.   Is there a door section in Home Designer Pro that can accommodate this?  If not, how should I compensate in my home design layout for such a door?
I am thinking you could make it as a bifold door 12' wide x 8' tall & change the panels to glass. It will show 2 doors stacking to each side. Change the door thickness to 1-3/4".
You might also be able to find a similar door in the 3D Warehouse and place it in to a "Doorway" opening in the wall to create the same look.
