SignatureEM Posted December 13, 2015 Share Posted December 13, 2015 Is there a way to hi light /mark out wall the will be moved, Demo or new framing in a different color? Link to comment Share on other sites More sharing options...
katalyst777 Posted December 15, 2015 Share Posted December 15, 2015 If your version doesn't allow you to modify the wall type to change the color or definition, you can still use the "Hatch Wall" tool to apply a hatching (which you can change to a solid color) to indicate those types of walls. Link to comment Share on other sites More sharing options...
SignatureEM Posted December 18, 2015 Author Share Posted December 18, 2015 Is there a way to hi light /mark out wall the will be moved, Demo or new framing in a different color. Im using 2016 pro Link to comment Share on other sites More sharing options...
DavidJPotter Posted December 18, 2015 Share Posted December 18, 2015 Pro 2016 has a "Hatch Wall" tool where you can use it to mark walls of your choice with a hatched fill. It is found under the "Build Menu - Wall - Hatch Wall", the hatching can be turned on or off in "Display Options - Wall - Hatch Wall" after you mark the hatch walls. This is explained in the Reference Manual under the section covering Wall Tools - Hatch Wall tool. Where you might want to show where demo walls used to be, you use 2D CAD in your as built copy of the plan and then "copy-paste-hold position" those outline CAD lines into your remodel plan, usually using a "dashed" line style. Adding a text annotation with an arrow is also a good idea to further delineate what they represent. DJP Also see this Knowledge Base Article about "Showing Demolition Walls" please Link to comment Share on other sites More sharing options...
