cxcarter Posted November 30, 2015 Share Posted November 30, 2015 Can someone please help me determine why I have a grass floor for a foundation in 3D view in the garage of the attached plan? practice_plan_11_29_15.plan Link to comment Share on other sites More sharing options...
DavidJPotter Posted November 30, 2015 Share Posted November 30, 2015 When I opened your plan copy, it had a concrete floor and no grass (no terrain plane actually too), so I created a terrain plane and still no grass in the garage. DJP Link to comment Share on other sites More sharing options...
katalyst777 Posted November 30, 2015 Share Posted November 30, 2015 If you have a different version of the plan which does have grass, it likely means either you don't have an enclosed room (so the terrain is showing inside of the garage), or maybe that you accidentally used the Material Painter on the flooring and changed it to a grass material. 1 Link to comment Share on other sites More sharing options...
Solution cxcarter Posted November 30, 2015 Author Solution Share Posted November 30, 2015 As it turns out, I had loaded a camera view of the plan that had grass, I'm assuming before the foundation was generated, and it did not change when the plan was updated. I deleted and reinstated the camera view and the foundation is now there. Thanks for your help! Link to comment Share on other sites More sharing options...
