RollingStone Posted November 27, 2015 Share Posted November 27, 2015 I haven't figured this out even after using this software for months. I'd like all dialogue boxes to display measurements in feet and inches rather than inches. I can't do the conversion in my head and am constantly using a side calculator to figure if 196" is 16' 4", etc. Hopefully this is an easy menu item/default someplace in the myriad of options and menu items. Thanks Link to comment Share on other sites More sharing options...
DavidJPotter Posted November 28, 2015 Share Posted November 28, 2015 In Home Designer Pro the only option is via "Edit - Default Settings - Dimensions - Format - Units" where you can globally change the way dimensions display, take a look at that dialog and practice changing the "unit" dropdown. In Chief Permier you can change the format defaults or a for a single dimension string but in Pro it is only via Default Settings. DJP Link to comment Share on other sites More sharing options...
ChiefTMunanga Posted April 30, 2023 Share Posted April 30, 2023 Does anyone know how to do this in Premier X15? There is no longer an "Edit - Default Settings - Dimensions - Format - Units" option. Link to comment Share on other sites More sharing options...
DavidJPotter Posted April 30, 2023 Share Posted April 30, 2023 Well this is the forum for Home Designer software and not Chief Architect Premier, never the less, I looked in my X15 and it is where it has been for many, many versions: Edit - Default Settings - Dimensions - Primary Format, where you can change the displayed units as you wish (decimal, inches only, feet and inches, etc.), you can choose under Secondary Format to also display metric dimension units along with Imperial, take a look, again, please. DJP Link to comment Share on other sites More sharing options...
