trailsnet Posted September 25, 2015 Share Posted September 25, 2015 I'm trying to build house plans for the first time using Home Designer Suite 2016. I started by using the terrain builder (no problem) for the lot, then I added the main house structure (no problem), then I tried adding a second floor. Laying out the second floor was no problem. But now it shows in the plans as if it's a completely separate entity from the first floor. (I've tried attaching a screenshot of how it looks on my computer screen to give you an idea, but I'm not sure if the screen shot will work.) Anyway, how do I get the second floor on top of the first floor so I can view it and work with it as one complete unit/house? Thanks. Link to comment Share on other sites More sharing options...
solver Posted September 25, 2015 Share Posted September 25, 2015 You could select the entire second floor and move it into place. Press F9 to show the reference display. Or just delete the 2nd floor and redraw. Build>Floor>Build New Floor 1 Link to comment Share on other sites More sharing options...
