ViperJuice Posted September 19, 2015 Share Posted September 19, 2015 How can I change the height of a single beginning or ending stair riser independent if the other risers? Link to comment Share on other sites More sharing options...
Solution solver Posted September 19, 2015 Solution Share Posted September 19, 2015 You cannot. You will need to use a landing or separate stair. 1 Link to comment Share on other sites More sharing options...
Kbird1 Posted September 19, 2015 Share Posted September 19, 2015 Eric is correct , this is because it is against Code to have different riser heights on the same staircase (tripping hazard) , hence the need to use one of the workarounds if needed. M. Link to comment Share on other sites More sharing options...
ViperJuice Posted September 19, 2015 Author Share Posted September 19, 2015 Eric/Mick, Thanks a bunch for the replies. I'm reconstructing the existing construction in order to have a fresh pallet for renovation. It's a 1912 row house so there are quite a few inconsistencies with modern code. I solved it with a separate step. Thanks again for the help. Link to comment Share on other sites More sharing options...
