ericepv Posted June 27, 2014 Share Posted June 27, 2014 I am using HD Pro 2015 and have been quite impressed with what it can do. I have spent quite a bit of time studying the help guide and adjusting my settings to maximize the quality of my renders but now I feel as though I have reached the limits of what the software can do. As an upgrade to Chief Premier is not currently on the horizion, I would like to know if anyone has experimented with using photo-editing software (I have GIMP 2.8) to acheive results that are similar to Chief Premier. Link to comment Share on other sites More sharing options...
Kbird1 Posted June 27, 2014 Share Posted June 27, 2014 Might be a question for the Chief Users on ChiefTalk a number of them are very good 3D Artists as well .....https://forums.chiefarchitect.com/ lot of other good info their for Pro Users too since Pro has about 1/4 of Chief's features. You would need software that can understand the 3d models Pro can export at a minimum is my guess .... I assume you have "played " with all the settings in the Edit>Prefs>Render> Final View Tab such as the % and size of Triangles, ? wont ever be Photo Realistic but maybe "good enough" M. Link to comment Share on other sites More sharing options...
ericepv Posted June 27, 2014 Author Share Posted June 27, 2014 Thanks Kbird, I'll give that forum a try. I have tweaked all of the settings as much as I can, my main issue is how the gloss surfaces look. I am getting very nice results but not what Chief Priemer can do, I am hoping there might be another way to enchance the image until I can make the jump to Premier. Link to comment Share on other sites More sharing options...
Kbird1 Posted June 27, 2014 Share Posted June 27, 2014 I have seen a few people mention Kerkythea actually which is free AFAIK but not aware of the details on it's usage.http://www.kerkythea.net Link to comment Share on other sites More sharing options...
DavidJPotter Posted June 27, 2014 Share Posted June 27, 2014 The problem with third-party render applications is that they use 3-D models and no Home Designer title exports such models in any 3-D format, so that narrows down your choices to image editing applications like Photoshop, Paint Shop Pro and others. Photo-realistic renderings start with a 3D model where you can then tweak materials and lighting to get that professional looking result. You might look at Sketch Up as a starting point, the professional version comes with add on features that can obtain stunning results but it is programmed completely differently from Chief Architect-Home Designer titles that use objects as opposed to lines and shadings. DJP Link to comment Share on other sites More sharing options...
Kbird1 Posted June 27, 2014 Share Posted June 27, 2014 Yes , Sorry Eric , I was forgetting that Pro can't export 3ds or obj models only import them..... Sketchup can work with Kerkythea with the Kerkythea addon though. M. Link to comment Share on other sites More sharing options...
ericepv Posted June 28, 2014 Author Share Posted June 28, 2014 Thank you all for your suggestions, look like I've got some research to do. Link to comment Share on other sites More sharing options...
