dave6115 Posted September 6, 2015 Share Posted September 6, 2015 I am trying to extend a gable roof out over a existing porch or deck, how is that done? Link to comment Share on other sites More sharing options...
DavidJPotter Posted September 6, 2015 Share Posted September 6, 2015 Depends upon what software you have, knowing that will then indicate what can and cannot be done. DJP Link to comment Share on other sites More sharing options...
WeebleSue Posted September 7, 2015 Share Posted September 7, 2015 Select the railing that is parallel to the house, and make that a gable wall. Voila, gable porch! I just did this on a plan I'm working on right now. | house | | | +-----------+ +----------+ | porch | +---------+ <-- make this a gable wall even though it is a railing. I did this in HDA 2015. Good luck! Susan Link to comment Share on other sites More sharing options...
Kbird1 Posted September 7, 2015 Share Posted September 7, 2015 As Sue pointed out if its a Porch the Roof will build auto if your move the railing out , Decks don't have Roofs by default, so you will need to turn Roofs back on in the Deck Room's DBX (dialog Box) on the Structure tab for it to show up after moving the Railing Link to comment Share on other sites More sharing options...
