dodge1930 Posted August 28, 2015 Share Posted August 28, 2015 Architectural 2016: I am trying to build a U shape staircase that has two landings connecting the stairs. Example: walk up 5 stairs onto a landing, turn 90 degrees step up onto another landing, turn 90 degrees and walk up 6 stairs. Luckily I have a picture. Any help would be great. Thanks Stephen Link to comment Share on other sites More sharing options...
solver Posted August 28, 2015 Share Posted August 28, 2015 What specifically are you having a problem with? Link to comment Share on other sites More sharing options...
WeebleSue Posted August 28, 2015 Share Posted August 28, 2015 This can only be done in the Pro version of the program. I have Home Design Architectural, and I am unable to make a double landing. If I'm not right, please let me know! Good luck, Susan Link to comment Share on other sites More sharing options...
Kbird1 Posted August 28, 2015 Share Posted August 28, 2015 It can't be done auto in Pro either , you must draw two landings and then rest the height of the second landing manually , I can try making a video if needed. (if DJP doesn't beat me to it ) 1 Link to comment Share on other sites More sharing options...
