Halcyon Posted August 8, 2015 Share Posted August 8, 2015 Can anyone please give me a pointer as to how I would finish 'sealing' off the staircase by running a small wall to the ceiling from the adjacent wall. Please view attached image. Thanks in advance. Pat Link to comment Share on other sites More sharing options...
solver Posted August 8, 2015 Share Posted August 8, 2015 So much work for something so simple Someone please tell us how easy this is. I'm sure there MUST be an easier way. I have attached the plan file so you can have a look for yourself. I did not do things in this order, so if something does not work, try again. 1) Extend the stair wall out so that it will cover the gap. Place a break at the corner where you extended the wall from. 2) Change the new wall (create a new wall type) to be solid paper. One layer, paper, 4.5" thick. Set it to Attic Wall. Realign with the stair wall. 3) In an elevation view, select the wall and drag it up forming a triangle. 4) Draw a Ceiling Plane at the same angle as the stair, covering the bottom of the exposed stair. You will need to lower it. Drag it over to cover the bottom of the triangle. 5) In a camera view, paint the new wall drywall so it blends in. Play with everything to get it looking correct. Setting to Attic Wall for some reason makes the program heal the walls -- try it with and without that setting. Making the new wall solid paper (other materials may work) lets the ceiling plane extend to its edge. If the new wall is drywall, the ceiling plane stops 1/2" shy, creating a visual problem. Stair Cover Up.planFetching info... Link to comment Share on other sites More sharing options...
Kbird1 Posted August 8, 2015 Share Posted August 8, 2015 The quick easy...move on to something else way... is the Triangle from the Shapes Library with the same color as the drywall applied , in some versions of HD it is the Only Way , since they can't edit walls in elevation. This is something that is being asked for as a Fix on the CT Forums too... M. Link to comment Share on other sites More sharing options...
solver Posted August 8, 2015 Share Posted August 8, 2015 Inverted Wedge is the shape you want. I knew about that, and even placed one in plan, but failed to see how it resized. Taking a second look, now I do. You vary the shape by dragging a side, not the corner. I always learn something from doing it the hard way, anyway. Link to comment Share on other sites More sharing options...
Kbird1 Posted August 9, 2015 Share Posted August 9, 2015 your are right about the "inverted wedge" , I was more thinking of the shape in a elevation view.... interesting find on the Attic Wall setting ..... Link to comment Share on other sites More sharing options...
Halcyon Posted August 9, 2015 Author Share Posted August 9, 2015 Thank you Mick and Eric.Easy once one gets a pointer in the right direction. Once I had done a search on 'shapes', I see that the inverted wedge has had a mention before. Attached an image of my completed job. Cheers. Pat Link to comment Share on other sites More sharing options...
Kbird1 Posted August 9, 2015 Share Posted August 9, 2015 Slabs and Soffits (cabinet menu) are also handy for "fixing" things if you think OTB a bit too. Link to comment Share on other sites More sharing options...
