chiefuserrick Posted August 6, 2015 Share Posted August 6, 2015 Can anyone suggest a method to create arched ceiling beams as are depicted in the attached picture? Link to comment Share on other sites More sharing options...
chiefuserrick Posted August 6, 2015 Author Share Posted August 6, 2015 Hi Eric, home designer Pro Link to comment Share on other sites More sharing options...
DavidJPotter Posted August 6, 2015 Share Posted August 6, 2015 You can't really duplicate what is in your picture without Chief Architect Premier OR make such custom constructs in "Sketch UP" and then import into HD Pro. Pro's ability to make custom objects on the fly is limited. Pro does have a truss tool and can make scissor trusses with a little extra effort but trusses with lath-turned shapes - not easily (I suppose anything is possible depending upon your patience and willingness to sweat blood for a result). Whether you use Sketch Up or Chief Premier such finely detailed work is time consuming and exacting. DJP Link to comment Share on other sites More sharing options...
