Several Truss Issues
mark2457
Hi Guys
Using HD Pro 10
Having many issues with trusses.
I have my framing complete
I can't add trusses without roof planes (asks me if I want to create general framing member)
Build roof planes:
Get this (roof planes hidden). I assume the walls have to be extended thru the gable at this point
Add first truss. All looks OK
Copy trusses
Seem to have truss and gable end wall
Seem to have birdsmouth cut on truss
Change end truss to dropped end. Lose overhang and it sinks into top plates
I figure I MUST be doing something wrong. Plan attached. Can anyone tell me where I'm gong wrong?
Thanks
Mark
01. Garage v3 (22x24f).plan
Truss height above "FF" is controlled in the "Build Roof Dialog- raise off plate input box", this gives you full z-axis control of trusses but MUST be done before auto building or manually building roof planes (Trusses follow the void created between the underside of the roof rafters and the flat ceiling of rooms, it this is not set up correctly you get what you got).
