Corrupted file
RollingStone
I tried to open both my plan files and get this message:
..\source\ChiefStreamableFactory.cpp(1163): Error #272030113
" Assertion failed: The plan file you are attempting to open appears to be corrupted. You should revert to a backup copy of this plan."
7/5/2015 4:51:42 PM
Is there anyway to recover anything from these files?  It's 4 hours of work.
There is an "Archive File" automatically created, usually to be found in "C://My Documents-Home Designer title- Archive", you might find a useful back up file there, take a look and see. If the archive file is also corrupted you have no other choices other than to start over. The only real insurance against such things happening is to thoroughly learn the software and use it as it was designed to be used. Too many guesses instead of personal studied certainty is the only long term solution to plan file corruption.
