jwturne Posted June 23, 2015 Share Posted June 23, 2015 Have been working up detailed retirement house plans (Pro 2012). Somewhere along the way I have lost individual room definitions for the first floor. Click on a first floor room and all the rooms light up. Even tried deleting a door to a bedroom and fully enclosed rooms are not enclosed......the whole floor plan inside the exterior walls lights up. This is a problem in defining individual room ceilings and floor coverings. Have searched the forum high and low and have not found anything. Help would be greatly appreciated. Thanks. Link to comment Share on other sites More sharing options...
DavidJPotter Posted June 23, 2015 Share Posted June 23, 2015 This is usually caused by one or more poor wall connections. The remedy is to carefully check them all and fix the ones that are weak. In the mean time, you can still access room dialog boxes by left-clicking on a room and then press the tab key or "Next" button to then select the room and then the room dialog box. DJP Link to comment Share on other sites More sharing options...
Kbird1 Posted June 23, 2015 Share Posted June 23, 2015 if you have more issues , post the plan file so someone can look at it for you, though I think David is right. Post the plan anyway , newer versions tell you if you have broken walls with a highlighted cursor , which will save you looking at every connection in the plan , as I or someone else can locate it quickly more than likely. . Link to comment Share on other sites More sharing options...
katalyst777 Posted June 23, 2015 Share Posted June 23, 2015 Visually it is usually pretty easy to tell where the problem wall connections are (I see it more with curved walls than anywhere else), even attaching a screenshot of the plan might help, or, as mentioned, attach the actual file. Link to comment Share on other sites More sharing options...
