DCortes Posted June 19, 2015 Share Posted June 19, 2015 HD Pro 2016 Question. Can you or can you not make blocks and add to your library for later use. I created a foundation block cross section and tried to save it but when you drag a box over to select all there is no option or Icon that shows Library with the Plus (+) sign with it to add to your personal Library. Or is this something that I have to create and save to a specific plan sheet and then have them all together and then copy and paste when needed. I think there should be an easier way to do this or maybe I'm wrong. Dave HD Pro 2016 Link to comment Share on other sites More sharing options...
solver Posted June 19, 2015 Share Posted June 19, 2015 Could you be more specific about what you are doing? You may save blocks -- I have entire kitchens saved as a single block. Link to comment Share on other sites More sharing options...
DCortes Posted June 19, 2015 Author Share Posted June 19, 2015 Ok here is which I am trying to do. To the left you will see what I am trying to save as a Block Cross Section Test.planFetching info... Link to comment Share on other sites More sharing options...
Kbird1 Posted June 19, 2015 Share Posted June 19, 2015 Only certain things are "Blockable" for those items not blockable ( no icon) you are correct in your statement : "have to create and save to a specific plan sheet and then have them all together and then copy and paste when needed." I think there should be an easier way to do this or maybe I'm wrong. There is in CA but not in Pro Link to comment Share on other sites More sharing options...
