Pcarlson
Foundation
How to build the foundation wall smaller than the basement wall on a terrain sloped terrain.
I builded a house on a sloped terrain with a basement floor (0) larger than the foundation floor 1, the dimension of the basement floor (0) is 70'x31' and the foundation floor 1 is 50'x31'. when I look at the basement floor (0) on 3D, found the terrain is inside the house, it only suppress the terrain following the side of the foundation floor, do anyone know how can we correct this. Many thanks
It is always better to Post pictures of your Problems , and without knowing What Software you are using , it is hard to say what will help since they all have different features.
Perhaps a Terrain hole will work?  but don't know what version you have , it may not be available?
Try searching the Old Legacy Forum , there maybe ideas there too....
Add your version no# to your profile signature , then you only have to add it once.
How do I upload the image or file? It shows error when I tried to attach the file.
you maybe uploading an unsupported file type? , the new forum has a 10mb limit too jpg or png for pics should work
the uploader window uses Flash9 apparently so use the basic uploader if you think that might be the issue.
and fill in your signature pls.
