Hannahobday Posted June 4, 2015 Share Posted June 4, 2015 Hi everyone I am currently using Home designer pro 2016, I have not had it long installed and I have a couple of issues. 1. when I do a wooden floor it just comes back as a block of colour so you don't see the planks, I have looked in the manual and online, I have tried it in 2014 which I still have loaded and it worked ok in that, but not in 2016 what am I missing? 2. Also does anyone know how I can remove the base board from around a fire place but still leave it in the rest of the room? Daft questions I know but it has been one of those days when sometimes things worked then they stop I have a break and then they work again lol. Thanks for any help. /Hanna Link to comment Share on other sites More sharing options...
solver Posted June 4, 2015 Share Posted June 4, 2015 Images of what you are seeing will help us help you. Link to comment Share on other sites More sharing options...
Kbird1 Posted June 4, 2015 Share Posted June 4, 2015 sound like you have toggled off textures same as in this post last week https://hometalk.chiefarchitect.com/index.php?/topic/1108-using-manufacturer-catalog-only-inserts-flooring-color-not-actual-flooring/ what kind of fireplace? cos normally the fireplace cuts the base out if positioned properly Link to comment Share on other sites More sharing options...
Hannahobday Posted June 5, 2015 Author Share Posted June 5, 2015 Thanks for the reply. I did do a search on the forum about the floor issue but nothing came up, must of not used the right words. I managed to find the toggle texture box and it seems a lot better now so thank you. I have attached an image of my fireplace, I usually have to try and make my fireplaces as they are different to the ones in the library, as you hopefully can see the base board come up in front of the fire and I don't want this, yeh the base boards are this high lol. Thanks again for your help. Link to comment Share on other sites More sharing options...
solver Posted June 5, 2015 Share Posted June 5, 2015 Looks like you have walls around the fireplace? Posting the plan would be the best way for us to help. You may use Edit>Edit Area to copy just this room to a new plan if you wish. Link to comment Share on other sites More sharing options...
Hannahobday Posted June 5, 2015 Author Share Posted June 5, 2015 Hi Yes I have used interior walls to sit the fireplace in (its a chimney breast, so its a flat wall on the external of the building but protrudes into the room by 230mm) this has been the best method I have found so far. I am also going to include the original picture of how the fireplace is set up so you can see what it looks like. Thanks again for your help. /Hanna Link to comment Share on other sites More sharing options...
solver Posted June 5, 2015 Share Posted June 5, 2015 I was suggesting you post the plan file, not an image of the plan. Keeps us from having to guess about what you have. Link to comment Share on other sites More sharing options...
Hannahobday Posted June 5, 2015 Author Share Posted June 5, 2015 Hopefully this is what you meant. fireplace. plan.planFetching info... Link to comment Share on other sites More sharing options...
solver Posted June 5, 2015 Share Posted June 5, 2015 That's what I needed. Suggest using a slab or custom counter top instead of a soffit for the hearth, as I believe a soffit automatically has any trim wrapped around it. Once I substituted a slab for the soffit, the baseboard was still wrong. I deleted the closet shelf (mantle), then put it back using Ctrl+Z. The base changed to be correct. Looks like a bug. Link to comment Share on other sites More sharing options...
Kbird1 Posted June 5, 2015 Share Posted June 5, 2015 yep that's what he meant makes it so much easier.. it is the Soffit you used for the fireplace hearth as soffits will take mouldings if they touch the room moulding so pulling it out of the wall a 1/4" or so fixes it. Looks like you have 3 different window Casings in that Room too not sure you need it but there is a KBA on doing insert fireplaces too http://www.homedesignersoftware.com/support/article/KB-00744/ *** looks like Eric and I posted at the same time and I had the same experience with Ctrl+Z Link to comment Share on other sites More sharing options...
Hannahobday Posted June 6, 2015 Author Share Posted June 6, 2015 Many thanks for your help, I will give this a go, will have to be Monday now but seeing as you have done it I now know that it is possible I am sure it will work. I will have to check the windows they are a pain all the side were different lengths has the frames all joined together and there should be four of them they look the same size but cant be if the 1330 wall has two windows in, so I have more investigating to do with this lol. Thanks again for your help /Hanna Link to comment Share on other sites More sharing options...
