Lizzilou10 Posted May 29, 2015 Share Posted May 29, 2015 Hi All, I need help once again. I have HDPro 2016 and, so far, I love it. But when I try to change a wall into a shower wall I have problems. On the floor plan it looks as though the regular interior wall has changed into a glass shower wall, but when I go to the 3D plan, it's just a regular interior wall. I've tried completing the room (tile, floor, etc.) and then creating a shower wall and I've tried creating a shower wall and then doing the rest (tile, floor, etc.). Either way, I end up with a regular interior wall. Thanks for any help as usual. Barb Link to comment Share on other sites More sharing options...
DavidJPotter Posted May 29, 2015 Share Posted May 29, 2015 Make a custom wall type that has only one layer and assign "Glass Block" as its material. If you just want a glass shower wall, use that wall type in the Wall Drop-down menu, replacing whatever wall type you started with. DJP Link to comment Share on other sites More sharing options...
Kbird1 Posted May 29, 2015 Share Posted May 29, 2015 could you post some pics or even the Plan perhaps ? I am not sure what you mean by a "showerwall" sorry. there is a link in my signature to a post on how to post pics and plans below if you need it , second line Link to comment Share on other sites More sharing options...
hannah707 Posted June 3, 2015 Share Posted June 3, 2015 Im having the same issue. I assign glass block or wall and the wall still looks like the interior walls that are around it. Were you able to resolve the issue Lizzie? Link to comment Share on other sites More sharing options...
Kbird1 Posted June 3, 2015 Share Posted June 3, 2015 Post the plan so we can look at what you have done see 2nd link in my sig. if needed. you can also try this http://www.homedesignersoftware.com/support/article/KB-00886/147/Home-Designer/Rooms/Creating-a-Custom-Glass-Shower.html or http://www.homedesignersoftware.com/support/article/KB-00583/ Link to comment Share on other sites More sharing options...
DavidJPotter Posted June 6, 2015 Share Posted June 6, 2015 I am just guessing but here is a You Tube Tutorial video of what I think you might be the ill effect of: http://youtu.be/iKDmui0q4lM http://youtu.be/iKDmui0q4lM http://youtu.be/iKDmui0q4lM DJP Link to comment Share on other sites More sharing options...
