Sign in to follow this
SayulitaDesign
Show in meters......
I am surprised I cant find this topic in the forums, but how do I use unit conversions to display meters as my default, all I am trying to do a this point is create  a terrain perimeter.
Thanks in advance
BEFORE or when you create a new plan file, you are offered the choice of Imperial or metric measuring units. You can control the nature of the measuring units chosen in Edit - Default Settings - Dimensions after your main choice is then made.
as David pointed out you must be in a metric plan to display in metric , however you can enter metric dimensions into any dialog box and HD will auto convert them to the equivalent imperial measurement if the rest of your plan was already "drawn" in Imperial
