joesausage Posted September 19 Share Posted September 19 Home Designer 2026, not Architect. I've got importing 3d models/fixtures figured out, but I can't reliably figure out light sources. I can add a light and mess around with it, but I don't seem to be able to create an "area light" property on imported fixtures so that, for example, a pendant light with a glass shell glows properly. It's either opaque or it isn't, so if I put the light source outside the shell the illumination works, but inside the shell, there's no light (because the shell is blocking it). Any suggestions here? I don't want to upgrade to Chief Architect to get this working. Link to comment Share on other sites More sharing options...
scottharris Posted Tuesday at 01:54 PM Share Posted Tuesday at 01:54 PM Home Designer does not have the symbol import that allows you to choose the symbol type like electrical lighting objects – see the example from Chief Architect Premier. So, what you might try – import the 3D model and place a light behind it so it appears to emit light. Link to comment Share on other sites More sharing options...
