DaveFite Posted Friday at 03:47 PM Share Posted Friday at 03:47 PM Could some knowledgeable expert please explain why my roof plan is torn? I've tried creating the roof several times and it always is incorrect at the same ridge. The two big roof planes are supposed to be at a 9" pitch and the small one at 12" pitch. Thanks! Hasemeier Residence_2026_08_21.plan Link to comment Share on other sites More sharing options...
Rookie65 Posted Friday at 07:13 PM Share Posted Friday at 07:13 PM There's a tool that looks like 2 triangles at an angle that is the roof connector. You click on the 1st roof, then the one you want to join it with. Plus make sure the break in the edges is the same distance from the ridge. Likely more of an explanation in the reference manual. Should update your signature now that you're using Home Designer 2027 too Link to comment Share on other sites More sharing options...
DaveFite Posted Saturday at 12:18 AM Author Share Posted Saturday at 12:18 AM Thank you for responding! Fixed the signature, but can't locate a roof connector tool. Is it under build roof? Tools pulldown? Searched the manual for "roof connector" with no results... Arrrgh! Link to comment Share on other sites More sharing options...
Rookie65 Posted Saturday at 01:16 AM Share Posted Saturday at 01:16 AM If you click one of the roof planes, look along the bottom tool bar towards the right side. Unless you have your tool bar set other than default. Or just search under "Roof." Link to comment Share on other sites More sharing options...
