Disconnected/double roof
HomeLinda
Go to solution Solved by HomeLinda,
Hello, could someone please point me in the right direction? I must have some weird setting that is causing a disconnected/double roof on a deck on the back of the house. I have auto rebuild roofs turned on. I can fix it if I turn it off but I would really like to get this right using auto rebuild roofs. Photos attached. Thank you so much for your help!! Linda
  • Solution
It wasn't either of those issues, but thank you, it caused me to explore other things, and I think I had the interior vaulted ceiling set too high - SMH - thanks again, I appreciate the response!
