Amateur hour typical roof issues
RubbleBuilt
Hi everyone,
First off, I apologize in advance for my limited experience and knowledge. I am a complete amateur and definitely not an architect or engineer. I’m trying to learn as I go, and I genuinely appreciate any patience or guidance.
I am currently designing a small cabin in Chief Architect and have run into an issue with my shed roof and wall heights that I cannot figure out.
Project specs:
  • Cabin size: 30' x 16'
  • Shed roof design
  • Roof pitch: 1.5/12
  • Intended wall heights:
    • Low wall: 8'
    • High wall: 10'
  • Vaulted ceilings throughout following the roof line (no flat ceilings anywhere)
The intended framing setup is:
  • Low shed wall:
    • 91 1/2" studs
    • 4 1/2" combined plates
    • 8' overall wall height
  • High shed/gable wall:
    • 115 1/2" studs
    • 10' overall wall height
  • Two side gable walls:
    • 91 1/2" studs
    • with rake walls built above following the roof slope
From my understanding, the math should work correctly:
1 1/2" x 16" = 24" 8'-10' 24" difference ?
So unless I am misunderstanding something fundamental, a 1.5/12 pitch across 16' should naturally create approximately 2' of rise, meaning an 8' low wall and 10' high wall should be achievable.
However, in Chief Architect, I cannot seem to get the roof/walls to generate correctly.
What I have tried:
  • Turned OFF “Flat Ceiling Over This Room”
  • Set my top plate/wall height to 96"
  • Set roof pitch to 1.5/12
  • Manually drew roof planes
  • Rebuilt roofs/framing multiple times
One thing that confused me even more is that I actually managed to get it working temporarily by splitting the structure down the middle with an interior dividing wall.
When I did that:
  • I could assign one side as the 8' section
  • and the other side as the 10' section
  • and the roof/framing generated properly
However, the cabin is intended to have an open interior with continuous vaulted ceilings from the 8' side to the 10' side.
As soon as I remove that dividing wall and rebuild framing/roof:
  • the high wall extends above and past the roof plane,
  • the wall heights become incorrect,
  • one stud shows approximately 121 13/16",
  • and the overall roof/wall intersection looks wrong.
At this point, I suspect the issue is probably related to:
  • Roof baseline settings
  • Wall definitions
  • Ceiling/roof relationships
  • Room definitions
  • Attic wall generation
  • Or how Chief calculates automatic roof generation in open vaulted spaces
rather than the roof geometry itself being impossible.
Could someone explain:
  1. The proper way to set up a simple open vaulted 8' to 10' shed roof in Chief Architect
  2. Whether I should be adjusting baseline height instead of wall height
  3. Why the high wall is extending past the roof plane
  4. Why the roof behaves correctly with a dividing wall but breaks once the space becomes open
  5. Whether my understanding of the roof math/framing logic is correct
I would really appreciate any explanations, corrections, or guidance. I am still learning and trying to better understand both framing concepts and the software itself.
Software/PC specs:
  • Chief Architect Premier X17 (latest version)
  • Windows
  • NVIDIA GTX 5050 8GB
  • 16GB RAM
  • Intel i5 2.20GHz
I will update this with plans/screenshots shortly as I am currently posting from a mobile device.
Thank you very much for your time.
please help lol.zip
