gwmcb49 Posted April 26, 2015 Share Posted April 26, 2015 How do I create a board and batten siding with different dimensions than the standard in the library? Link to comment Share on other sites More sharing options...
solver Posted April 26, 2015 Share Posted April 26, 2015 Give the forum a search for "batten". This was discussed last year. Link to comment Share on other sites More sharing options...
Kbird1 Posted April 26, 2015 Share Posted April 26, 2015 This is my post on it last year , post back if the file doesn't work and I'll try to figure out why..... https://hometalk.chiefarchitect.com/index.php?/topic/499-how-to-draw-board-and-batten-siding/#entry2664 1 Link to comment Share on other sites More sharing options...
katalyst777 Posted April 27, 2015 Share Posted April 27, 2015 There is no true 3D Board and Batten available but there is a board and batten siding option in the CertainTeed Library in newer versions under siding/vinyl siding/vertical siding. You can then apply any material to it as needed eg a real Cedar look. That option isn't available to me in Pro 10 so earlier this year I dug around the old Forums here, and here is what I managed to make using info from some old threads and a texture found here too. Board and Batten 8-10-12 inch_Vector.JPG 3 different Sizes being standard 1x8,1x10 and 1x12 with a 1x2" batten over the joints, once again it isn't true 3D, they will import into your User Library as Board and Batten 8,10 and 12". If they don't look right let me know and I'll figure out why but I don't think you need the pattern file since you are importing them as materials. Board and Batten 8-10-12inch_MHD.calibz It doesn't take too much to copy/paste what was in the earlier referenced thread to save some time searching. Link to comment Share on other sites More sharing options...
Kbird1 Posted April 27, 2015 Share Posted April 27, 2015 Thanks Kat I didn't think the pic (excuse the feeble Mouse writing) or download link would stay "live" if I did that. M. Link to comment Share on other sites More sharing options...
