TheMadCadder Posted November 19, 2025 Share Posted November 19, 2025 Can someone point me to the setting to control the positioning of the auto text for door & window callouts? Currently (out of the box) my door & window size text is located directly atop the doors & windows. The default exterior door text sits outside the wall, as I'd like it but not the interior doors or the windows text. Link to comment Share on other sites More sharing options...
Rookie65 Posted November 19, 2025 Share Posted November 19, 2025 You can go into the DBX for the windows under labels & hit the "enter" key a time or two to move the label to sit below the window. It may work for the doors too. You can always click on the door or window and move the text with the small dot in the center of the call out too Link to comment Share on other sites More sharing options...
TheMadCadder Posted November 19, 2025 Author Share Posted November 19, 2025 I really hate to have to do that for every opening...on every plan...and every time an opening changes. There's got to be a default setting for openings text position...or is that only a CA thing? Link to comment Share on other sites More sharing options...
Rookie65 Posted November 19, 2025 Share Posted November 19, 2025 If you set it in your defaults before you start adding windows, it'll happen with them all Link to comment Share on other sites More sharing options...
y-g-m-n Posted November 20, 2025 Share Posted November 20, 2025 No reason to have in floor plan. Create a window and door list Link to comment Share on other sites More sharing options...
TheMadCadder Posted November 21, 2025 Author Share Posted November 21, 2025 17 hours ago, y-g-m-n said: No reason to have in floor plan. Create a window and door list schedules are de' debbil Link to comment Share on other sites More sharing options...
y-g-m-n Posted November 21, 2025 Share Posted November 21, 2025 4 hours ago, TheMadCadder said: schedules are de' debbil uh----- whats that mean? 1 Link to comment Share on other sites More sharing options...
TheMadCadder Posted November 21, 2025 Author Share Posted November 21, 2025 On 11/20/2025 at 12:41 AM, y-g-m-n said: No reason to have in floor plan. Create a window and door list 13 hours ago, TheMadCadder said: schedules are de' debbil 8 hours ago, y-g-m-n said: uh----- whats that mean? It means I do not use opening schedules in my plans and so it is not a solution to the problem I am working on. Link to comment Share on other sites More sharing options...
TheMadCadder Posted November 21, 2025 Author Share Posted November 21, 2025 On 11/19/2025 at 11:47 AM, Rookie65 said: If you set it in your defaults before you start adding windows, it'll happen with them all I've been all through the defaults and do not see where this is possible to do...where in the defaults would I set this? Ok...after a bit of experimenting I've solved the first issue... By setting the default window label to "specify label" and then typing in the following in the dbx; <carriage return> <carriage return> %automatic_label% I get an automatic label that is located just outside the exterior wall as I would like...however, the <carriage returns> appear to act as text (not transparent) and now hides the window in plan like its "whited out"... Suggestions? Link to comment Share on other sites More sharing options...
Solution Rookie65 Posted November 21, 2025 Solution Share Posted November 21, 2025 Make the box transparent. Maybe spend some time going over the reference manual Link to comment Share on other sites More sharing options...
TheMadCadder Posted November 22, 2025 Author Share Posted November 22, 2025 21 hours ago, Rookie65 said: Make the box transparent. Maybe spend some time going over the reference manual Thanks! Link to comment Share on other sites More sharing options...
donovanjar Posted Monday at 01:26 PM Share Posted Monday at 01:26 PM You could also try grouping your door and window callouts on separate layers, making it easier to handle visibility. This might help manage any overlaps or clarity issues. Glad the problem was solved! 1 Link to comment Share on other sites More sharing options...
Rookie65 Posted Monday at 02:52 PM Share Posted Monday at 02:52 PM There are no separate layers in Home Designer products like there are in Chief Architect. Either you show the labels or not. 1 Link to comment Share on other sites More sharing options...
