Fjohnston Posted August 1, 2025 Share Posted August 1, 2025 There is quite a bit of missing or incorrect information about grouping objects or making architectural blocks on this and other sites. Firstly: the "make architectural block" icon or symbol (which no posts seem to mention) is a graphic of a 3D perspective of a "cube" which appears in the lower left tool bar (at least on my version - Home Designer Pro 2021).and does NOT appear under the EDIT tab on the main menu as some tips suggest. Secondly: it does NOT appear, and is apparently NOT functional, if you select CAD objects such as a square or a circle. Nor does is appear if you select windows, doors, or walls. Thirdly: simply copying & pasting multiple CAD objects, windows, doors, & walls does work using the regular copy and past procedure. Link to comment Share on other sites More sharing options...
Robborito Posted August 2, 2025 Share Posted August 2, 2025 Creating Architectural Blocks To create an architectural block, group-select multiple architectural objects, then click the Make Architectural Block edit button. Architectural blocks can be created in any view. See Architectural vs CAD Objects . The following is a list of objects that can be included in ... Manual/Architectural Blocks/Creating_Architectural_Blocks.htm NB Architectural objects excl. lines and walls ... An architectural block is a collection of individual 3D objects that are grouped together so that they can be placed and moved as a single object. Select objects and the appropriate icon appears on screen for selection to make a block.(Made same mistake myself) see help... Link to comment Share on other sites More sharing options...
