LancasterLinda Posted June 20, 2025 Share Posted June 20, 2025 This deck requires 2 border planks. However, when I tell the system to create 2 borders, it does nothing - even after "reframing". Any clues why it's not working?? I'm running Home Designer Pro 2025 on a MSI laptop. Thanks in Advance!! Linda Link to comment Share on other sites More sharing options...
scottharris Posted June 22, 2025 Share Posted June 22, 2025 A couple of things to verify 1) automatic deck framing is turned on and, 2) the # of deck border planks. Still not working? Post your plan. Link to comment Share on other sites More sharing options...
LancasterLinda Posted June 24, 2025 Author Share Posted June 24, 2025 Just saw your answer, Scott. I contacted Tech Support before seeing your response and sent the file. Kris found the culprit - my deck wasn't completely "attached" to the house at one point/corner preventing the deck from creating the borders. Thank you for your input, though!!! I did just post another question about being able to have window casing a different material/color from the sill. If I change one, both change. Any thoughts?? Linda in Lancaster (Ohio) :-) Link to comment Share on other sites More sharing options...
