LancasterLinda Posted Friday at 02:46 PM Share Posted Friday at 02:46 PM This deck requires 2 border planks. However, when I tell the system to create 2 borders, it does nothing - even after "reframing". Any clues why it's not working?? I'm running Home Designer Pro 2025 on a MSI laptop. Thanks in Advance!! Linda Link to comment Share on other sites More sharing options...
scottharris Posted Sunday at 01:02 AM Share Posted Sunday at 01:02 AM A couple of things to verify 1) automatic deck framing is turned on and, 2) the # of deck border planks. Still not working? Post your plan. Link to comment Share on other sites More sharing options...
LancasterLinda Posted yesterday at 10:39 PM Author Share Posted yesterday at 10:39 PM Just saw your answer, Scott. I contacted Tech Support before seeing your response and sent the file. Kris found the culprit - my deck wasn't completely "attached" to the house at one point/corner preventing the deck from creating the borders. Thank you for your input, though!!! I did just post another question about being able to have window casing a different material/color from the sill. If I change one, both change. Any thoughts?? Linda in Lancaster (Ohio) :-) Link to comment Share on other sites More sharing options...
