Hiding Exterior Wall Material in Elevation View
AndrewDraws
Go to solution Solved by solver,
I am creating some layout drawings for a renovation. The house has siding on the exterior. I find all the horizontal lines of the siding distracting when including dimension lines, so I would like to hide the external layer. However, I can't find anything in lays like Walls, External.
How can I hide the exterior wall material, without going into each wall and changing the material?
I'm using Home Designer Pro 2024
Many thanks!
